7960 Sip to skinny
Hi all,
i have problem to load skinny firmware to ip phone on which is sip load running. I changed OS79XX file and added skinny firmware for "upgrade software" and
immediately reset itself. This procedure is continously repeating.
Does anybody have similar expierence?
martin
Silver
Re: 7960 Sip to skinny
Try P0S30203.bin. Also try to upgrade to the SIP image and then move to Skinny firmaware
How to Convert a Cisco 7960 CallManager Phone to a SIP
Phone and the Reverse Process - explaine din the below URL
http//www.cisco.com/warp/public/788/voip/handset_to_sip.html
Hi Martin,
I noticed the same. The problem is that the skinny phone load names are longer the 8.3 If you rename the skinny load to a shorter name it will work
regards,
Bas
113
