7961 phone not coming up.
I have a 7961 phone and it has been working for 2 days. Just today, the phone is not coming up. I then used another power module incase the other one is bad. I noticed that the keys and headset key shows light and goes off but nothing displays on the screen. The screen remains blank. Can anybody help ?
Hall of Fame Super Red
Re: 7961 phone not coming up.
Hi Ahmad,
Can you perform this procedure:
Power off the phone.
Hold down the # key.
While holding #, connect an AC adaptor to the phone.
Continue to hold # until the line buttons blink amber.
Release the # key.
Enter 3491672850*#
The lights should change color from amber to red. When this occurs, the phone is resetting to factory defaults.
Note: It is important to try this procedure with a external power supply.
From this good Tac doc (thanks Paolo!);
http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K43691258
Hope this helps!
Rob
Hi Rob,
Thank you for your reply, but the problem still the same, The screen remains blank.
169
