7970 Firmware CCME 3.2
Hi, I'm configuring a CallManager Express 3.2. I'm installing two types of IP Phones: 7940G and 7970G. I haven't could find the firmware for the 7970G IP Phone for this version of CallManager Express. Thanks.
Blue
Re: 7970 Firmware CCME 3.2
this would be the same phone load(s) that you can download from CCO.
see this link for latest the 7970 load: (cco account w/software maintenance required)
http://www.cisco.com/cgi-bin/Software/Tablebuild/doftp.pl?ftpfile=cisco/voice/ip-7900ser/cmterm-7970-7971-sccp.8-0-3.zip&app=Tablebuild&status=showC2A
Depending on the release of 3.2 that you're using, you can either use 6.0(3)SR1 or 7.0(1). Both can be found here:
http://www.cisco.com/cgi-bin/tablebuild.pl/ip-iostsp
Also, take a look at this link regarding configuring the 7970 with CME 3.2.1.
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_example09186a008042326b.shtml
Hope this helps. If so, please rate the post.
Brandon
Thanks for your help. This CallManager Express doesn't have any release, the version is 3.2. I just tried to use firmware for CCME 3.2.1, however it doesn't work. If you have other suggestion, please send it to me.
On the router, type "show telephony-service". You should see your version at the top.
Brandon
132
