12-19-2006 11:00 AM - edited 03-15-2019 04:45 AM
I am using callmanager express 4.0 and wish to update the firmware loads on a 7970g phone, I have downloaded the latest updates as shown below :
cnu70.2-7-6-26.sbn
CVM70.2-0-2-26.sbn
Jar70.2-9-2-26.sbn
TERM70.7-0-3-0S.loads
term70.default.loads
After extracting all the files into flash, I configured all the files under tftp-server flash: as shown
tftp-server flash:cnu70.2-7-6-26.sbn
tftp-server flash:CVM70.2-0-2-26.sbn
tftp-server flash:Jar70.2-9-2-26.sbn
tftp-server flash:TERM70.7-0-3-0S.loads
tftp-server flash:term70.default.loads
But I am unsure as to which file to load under telephony-service for "load 7970 filename" ???
Checking ciscos link for more information about updating the 7970 at
It says : "Read the "Read Me" files included with Cisco software updates. These files provide important updated information about installing and configuring the new software." but there is no readme file with the firmware update ?
A bit confusing any help would be appreciated ?
12-19-2006 12:15 PM
Hi Mark,
Perhaps this will help, I am pretty sure that you would use;
load 7970 TERM70.7-0-3-0S
Upgrading Individual Phone Firmware Files
From this good CME doc;
Hope this helps!
Rob
Please remember to rate helpful posts.....
12-20-2006 10:37 AM
Thanks Rob did the trick :)
