Cisco 2811 running in 12.3(14)T or 12.4(4)T have the same result, the 7960 phone get the same extension in SRST mode as in CM mode but the 7970 phone get extension 4000 in SRST mode. In CM mode, the extension of the 7970 is 7004.
The callmager is running 4.1(3)SR1, upgrade to SR2 have the same result.
The firmware of 7970 have changed several version to test, the same result. change another set of 7970 phone, the phone get 5775 in SRST mode, the phone extension is 7009 in CM mode.
Debug ephone register get the following:
ephone-2 Mac:000D.EDAB.6F6A TCP socket:[2] activeLine:0 REGISTERED
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0
IP:10.1.2.23 50444 Telecaster 7960 keepalive 2 max_line 6
button 1: dn 1 number 7002 CM Fallback CH1 IDLE CH2 IDLE
ephone-3 Mac:0014.F245.03C8 TCP socket:[-1] activeLine:0 DECEASED
IP:10.1.2.27 3935 7970 keepalive 3 max_line 8
Partial config is listed below:
voice-port 1/0/0:23
ccm-manager fallback-mgcp
ccm-manager mgcp
mgcp
mgcp call-agent 10.1.2.3 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp modem passthrough voip redundancy
mgcp profile default
dial-peer voice 102 pots
service mgcpapp
port 1/0/0:23
dial-peer voice 10 pots
destination-pattern 9T
incoming called-number .
direct-inward-dial
port 1/0/0:23
call-manager-fallback
max-conferences 6 gain -6
timeouts interdigit 4
timeouts ringing 120
ip source-address 10.1.2.3 port 2000
max-ephones 42
max-dn 50 dual-line
access-code pri 9T direct-inward-dial
date-format dd-mm-yy
Thanks in advance for any information!!
Michael.
