7970 Phone load- CCM 3.3
Setup installed with CCM 3.3
After installing 7970 -cmterm-7970-sccp.5-0-3.exe also in the CCM 7970 phone load is not coming in the device defaults.
Should i install the patches for CCM 3.3 and check this out?
Sundara Rajan.R
Re: 7970 Phone load- CCM 3.3
do you see the phone load file in the TFTP folder in callmanager ? If you can see the file, try manually specifying the phone load name in the device defaults page.
Manually how can the phone load name can be specified in the device defaults page?
There are no option for creating any new field .
Sundara Rajan.R
No need to create a new field. On the device defaults page you have each load file name specified in a text box against the corresponding IP Phone. Change the value in the text field to reflect the new file name. You can get the file name by looking at the TFTP folder in the Callmanager.
Make sure you have applied at least SR2 for 3.3(3) to provide support for the 7970.
288
