10-09-2007 07:24 AM - edited 03-13-2019 04:30 PM
My phones are running 8.2(1)S firmware and want to fix them up for the DST problem. What firmware version is recommended by Cisco or other techs?
10-09-2007 07:33 AM
Firmware version 8.2(1) has a fix for DST. The following link has information about what is the miniumum required Software version for DST fix.
http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K33353530
Also, incase you would like to upgrade the firmware, I'd recommend upgrading to the latest version. You can download the latest version from:
http://www.cisco.com/cgi-bin/tablebuild.pl/ip-7900ser
Hope this helps
10-09-2007 08:16 AM
Your first link about 8.2(1)S states that it has a bug that if the phones are unpluged it looses the DST and you have to reset it in CM to fix it and they recommend upgraded to
8.2(1)ES5 or 8.2(2)
Which version do you recommend? Also does this apply to CM Express or just CM server.
10-09-2007 10:06 AM
Hi Steven,
Just to add a note to the great info from Mahesh :) 8.2(2) would be an excellent choice. This is what many people have successfully applied to combat the dreaded DST issues. 8.3(1) will also work.
For third generation phones in CME these are supported firmware verions as well.
Hope this helps!
Rob
10-10-2007 02:18 PM
i would agree that 8.2(2) is the right step. i actually just ran into a bug with 8.3(1)S with the berbee informacast application and had to revert to 8.2(2) on a callmanger 4.3 deployment.
FYI - the bug i ran into was when you press the services button and get the berbee menu, you cannot select any items from the list of recordings, the buttons are not responsive. you had to press the exit button, re-select the berbee service and then you could select the message you wanted to broadcast. The berbee people have a developer case open with cisco now but i am not sure when a fix will be out.
Mike
