837 with LLQ configured will not seize the bandwidth
Sorry if this is the wrong forum. Could not see a specifically QoS one.
I have a query regarding implementing LLQ on an 837. I understand that the service policy out command has to be input on the int atm0 interface rather than the dialer interface. All the commands take. However, when a sh run is performed, then the service-policy command does not appear underneath the int atm0.
But the logs show this error:
I/f ATM0 VC 0/38 class voice-rtp requested bandwidth 200 (kbps), available only 0 (kbps)
Adding the bandwidth command under the int atm0, has been tried, but to no avail.
Any feedback would be much appreciated.
Rgds
Marc
Re: 837 with LLQ configured will not seize the bandwidth
can you post your config and a "show atm pvc"?
Did you follow this guide: "QoS Solutions for PPPoE and DSL Environments"
http://www.cisco.com/en/US/tech/tk543/tk545/technologies_tech_note09186a00800b2d29.shtml
and does your config look similar to
policymap P2
class c1
priority Y
class c2
bandwidth X
interface ATM0/0/0.132 point-to-point
pvc 1/32
vbr-nrt 2000 2000
encapsulation aal5snap
protocol pppoe
service-policy output P2
The vbr bandwidth should be the available bandwidth for your policy. If you just use the "pvc" command the PVC type defaults to UBR, which has a bandwidth of 0 kbps. Maybe this causes the observed behaviour.
Regards, Martin
Thanks Martin. That is most helpful. Yes, I was not sure abut the UBR and VBR settings. We are using pppoa, i.e.
encapsulation aal5mux ppp dialer
So I was not sure about using the vbr-nrt command. Are the figures after that in kbps?
Rgds
Marc
Hi, the values are in kbps.
Regards, Martin
Silver
Should the output service-policy be applied under the PVC in a PPPoA configuration too, rather than the dialer?
124
