08-21-2009 12:40 PM - edited 03-13-2019 06:36 PM
I use a Cisco 800 Wireless Router--with wireless enabled, my VoIP Provider tells me I am using 99% of my T1 bandwidth. With the wireless radio disabled, my usage drops to 4%. WEP Encrypted password; "probably" no one is stealing signal to broadcase video, which is about what it would take to use 95% of a T1. Any thoughts at all? (We're a small graphic design company with mostly Macs - T1 in, converted to the Cisco router, then a non-managed 24 port switch -- very simple network. Use the wireless mostly for client convenience.
Thanks for any suggestions!
08-21-2009 02:41 PM
I would start with changing the key (and encryption to WPA), then enabling the radio. Does the traffic load immediately return even with a new key?
08-21-2009 03:44 PM
Thanks for the response. I'll try WPA encryption on Monday and ask the VoIP provider if the usage drops. By the way, do you know of a small tool to look at usage myself?
08-23-2009 07:47 AM
Try prtg.
You can also check usage with "show interface".
I would leave radio setting alone for now. You can check who is connected with "show dot associa"
