9T not working
Guys,
I have a 3745 with CCME connected to a 9 timeslot PRI (VWIC). We have about 20 DIDs. Everything seems to be working fine as long as I have either T or .T configured for my outgoing calls.If I put 9T (which is what I would like to have, because it would resolve a bunch of other problems I've been having), I cannot dial out. It gives me "unknown number".
The current config is
dial-peer voice 1 pots
destination-pattern .T
forward-digits all
port 0/0:23
When I put 9T, I remove forward-digits all from the config. Has anyone had a problem like this?
Respect,
Dragi
mschlenger
Level 3
Level 3
Try this configuration. Remove the forward digits all.
incoming called-number . <--don't forget the period
destination-pattern 9T
progress_ind alert enable 8
progress_ind progress enable 8
direct-inward-dial
port 0/0:23
If this does not work, provide a snapshot of a "debug isdn q931".
It didn't work. This is what I got from deb isd q931:
Jan 27 17:54:22.246: ISDN Se0/0:23 Q931: TX -> SETUP pd = 8 callref = 0x0057
Bearer Capability i = 0x8090A2
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98389
Exclusive, Channel 9
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0080, '9045437054'
Plan:Unknown, Type:Unknown
Jan 27 17:54:22.322: ISDN Se0/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8057
Cause i = 0x82E0 - Mandatory information element missing
Respect,
Dragi
trailman73
Level 4
Level 4
I have the same setup. You may try to change the pots number from a 1 to 90. I can't remember where, but I think this makes a difference. Here is my working dial-peer:
dial-peer voice 90 pots
progress_ind setup enable 3
direct-inward-dial
port 1/0:23
Geoff
That actually nailed it, my friend. Thank you very much!
Much respect,
Dragi
