A Caller phone number issue
Hi ,
I have a gw cisco 2600 using E1-ISDN and R2-digital to terminate voice traffic in the local PSTN. When some call are terminated by that gw the called number can identify my access phone number (the phone number of my E1s ).
Does Anybody knows how avoid it?? I mean , when my gw terminate a call the called number could not identify the access number of my gw.
(like a international call that is received in a mobile phone and the caller are identified like 000000 or Private).
thanks in advance for any help.
Luiz
Silver
Re: A Caller phone number issue
Luiz,
You can use a simple translation rule and block your ani going out to the pstn.
translation-rule 1
rule 1 any 00000
dial-peer voice 1 pots <--- this should be YOUR pots dial peer
translate-outgoing calling 1
This will change your ani to 000000 on the outbound peer and thats what the users will see.
Hope that answers your question.
Hi thusain ;
Thanks a lot for your help. It will be very useful.
Luiz
Hi Thusain ;
I did the configuration as you recommend, in despite of the test works ok, the ANI continue displaying to destination (I think is something of local PSTN : I'm using E1-ISDN to connect to PSTN.).
See below my configuration (If you have some suggestion , Please tell me!!)
thanks in advance,
Luiz
controller E1 1/0
pri-group timeslots 1-31
translation-rule 1
Rule 1 55 031
translation-rule 2
Rule 1 any 000000
dial-peer voice 2 pots
destination-pattern 21T
translate-outgoing calling 2
port 1/0:15
dial-peer voice 4 pots
destination-pattern 55T
translate-outgoing called 1
port 1/0:15
GW_Golden#test translation-rule 2 66666666
The replaced number: 000000
Luiz
105
