A missed call is rejected when forwarded
Setup:
CCM 4.1.3
H.323 GW
Here is the scenario:
All calls to any extention in partition_X are forwarded to 0900 if not answered (no answer internal, and external). There is nothing wrong with this setting, and it works fine for all calls.
Exeption:
If a call is made to xxxx in partition_X, and this call is forwarded to yyyy in the same partition but not answered. The call is rejected.
At the gateway this is what I see:
Aug 9 12:30:33.870: %ISDN-6-DISCONNECT: Interface Serial0/0/0:28 disconnected from 21632160 , call lasted 344 seconds
Aug 9 12:30:33.882: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x255F
Cause i = 0x8090 - Normal call clearing
Aug 9 12:30:34.102: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0xA55F
Aug 9 12:30:34.106: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x255F
Aug 9 12:30:45.415: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x00E5
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA18386
Preferred, Channel 6
Calling Party Number i = 0x2183, 'XXXXXXXX'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, '53051144'
Aug 9 12:30:45.439: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x80E5
Channel ID i = 0xA98386
Exclusive, Channel 6
Aug 9 12:30:45.463: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8 callref = 0x80E5
Aug 9 12:30:48.279: ISDN Se0/0/0:15 Q931: TX -> CONNECT pd = 8 callref = 0x80E5
Aug 9 12:30:48.311: ISDN Se0/0/0:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x00E5
Aug 9 12:30:48.311: %ISDN-6-CONNECT: Interface Serial0/0/0:5 is now connected to XXXXXXXX N/A
Aug 9 12:31:21.680: %ISDN-6-DISCONNECT: Interface Serial0/0/0:5 disconnected from XXXXXXXX , call lasted 33 seconds
Aug 9 12:31:21.684: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x80E5
Cause i = 0x8095 - Call rejected
Aug 9 12:31:21.720: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x00E5
Aug 9 12:31:21.724: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x80E5
Parts of the ccm logfile is attaced.
A short explanation of what you need to know:
CNA are forwarded to DN 0900 in partition_X. 0900 is translated to DN 3002 in partition_Y.
3002 is a Routepoint for the attendats (using Netwise). The call is then placed in ctiports for queueing.
3000000 is the DN of the first cti. (as shown in ccmlogfile)
I can't see any location/bw errors here, and I am at a loss. Help apreciated
Lasse
1 REPLY
Silver
Re: A missed call is rejected when forwarded
Line interruptions due to an external source can result in this symptom. These include physical separation of the cabling, red or yellow T1 alarms, or lightning striking somewhere along the network.
177
