a problem with NAT on a stick
This is a cisco 1721 router ,I configure it with NAT on a stick, the configuration is follow...
Building configuration...
Current configuration : 1258 bytes
version 12.3
hostname aaa
boot-start-marker
boot-end-marker
enable secret xxxx
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
no ip domain lookup
no ftp-server write-enable
interface Loopback0
ip address 10.0.1.1 255.255.255.252
ip nat outside
interface Ethernet0
ip address 192.168.66.88 255.255.255.0 secondary
ip address 10.0.0.2 255.255.255.0
ip nat inside
ip policy route-map nat-loop
half-duplex
interface FastEthernet0
no ip address
shutdown
speed auto
ip nat pool external 192.168.66.5 192.168.66.6 prefix-length 30
ip nat inside source list 10 pool external overload
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.66.66
no ip http server
access-list 10 permit 10.0.0.0 0.0.0.255
access-list 102 permit ip any 192.168.66.4 0.0.0.3
access-list 102 permit ip 10.0.0.0 0.0.0.255 any
access-list 177 permit icmp any any
access-list 177 permit icmp any any log
route-map nat-loop permit 10
match ip address 102
set ip next-hop 10.0.1.2
line con 0
line aux 0
line vty 0 4
password cisco
login
end
aaa#
Connection to host lost.
I can see some NAT translation entry :
aaa#show ip nat translations
Pro Inside global Inside local Outside local Outside global
udp 192.168.66.6:1214 10.0.0.112:1214 202.96.128.68:53 202.96.128.68:53
udp 192.168.66.6:1214 10.0.0.112:1214 202.96.128.143:53 202.96.128.143:53
icmp 192.168.66.6:768 10.0.0.112:768 202.96.128.143:768 202.96.128.143:768
udp 192.168.66.6:3 10.0.0.112:138 10.0.0.255:138 10.0.0.255:138
aaa#
But on my PC (10.0.0.112) can't connection the internet, can't ping the internet, Why ???
If my router's configuration is wrong , please tell me ,thanks
I configure the above is according the cisco's article,
http://www.cisco.com/en/US/tech/ ... 86a0080094430.shtml
Re: a problem with NAT on a stick
My debug output:
User Access Verification
Password:
aaa>en
Password:
aaa#show
aaa#de
aaa#deb
aaa#debug ip pac
aaa#debug ip packet
IP packet debugging is on
aaa#ter
aaa#terminal mi
aaa#terminal min
aaa#terminal mino
aaa#terminal m
aaa#terminal moo
aaa#terminal mo
aaa#terminal mon
aaa#terminal monitor
aaa#
*Mar 1 00:31:45.999: IP: s=10.0.0.2 (local), d=10.0.0.5 (Ethernet0), len 63, se
nding
*Mar 1 00:31:46.143: IP: tableid=0, s=10.0.0.5 (Ethernet0), d=10.0.0.2 (Etherne
t0), routed via RIB
*Mar 1 00:31:46.143: IP: s=10.0.0.5 (Ethernet0), d=10.0.0.2 (Ethernet0), len 40
, rcvd 3
*Mar 1 00:31:46.239: IP: tableid=0, s=10.0.0.5 (Ethernet0), d=10.255.255.255 (E
thernet0), routed via FIB
*Mar 1 00:31:46.239: IP: tableid=0, s=10.0.0.5 (Ethernet0), d=10.0.0.2 (Etherne
t0), routed via RIB
*Mar 1 00:31:46.243: IP: s=10.0.0.5 (Ethernet0), d=10.0.0.2 (Ethernet0), len 42
, rcvd 3
*Mar 1 00:31:46.243: IP: tableid=0, s=10.0.0.2 (local), d=10.0.0.5 (Ethernet0),
routed via FIB
*Mar 1 00:31:46.243: IP: s=10.0.0.2 (local), d=10.0.0.5 (Ethernet0), len 42, se
nding
*Mar 1 00:31:46.259: IP: tableid=0, s=10.0.0.2 (local), d=10.0.0.5 (Ethernet0),
routed via FIB
*Mar 1 00:31:46.579: IP: tableid=0, s=192.168.66.154 (Ethernet0), d=192.168.66.
255 (Ethernet0), routed via RIB
*Mar 1 00:31:46.579: IP: s=192.168.66.154 (Ethernet0), d=192.168.66.255 (Ethern
et0), len 202, rcvd 3
et0), len 78, rcvd 3
*Mar 1 00:31:47.095: IP: tableid=0, s=10.0.0.2 (local), d=10.0.0.5 (Ethernet0),
routed via FIB
*Mar 1 00:31:47.099: IP: tableid=0, s=10.0.0.2 (local), d=10.0.0.5 (Ethernet0),
routed via FIB
*Mar 1 00:31:47.327: IP: tableid=0, s=192.168.66.154 (Ethernet0), d=192.168.66.
*Mar 1 00:31:47.327: IP: s=192.168.66.154 (Ethernet0), d=192.168.66.255 (Ethern
*Mar 1 00:31:47.863: IP: s=192.168.66.6 (Ethernet0), d=202.96.128.143 (Loopback
0), g=10.0.1.2, len 70, forward
*Mar 1 00:31:47.863: IP: s=192.168.66.6 (Ethernet0), d=202.96.128.68 (Loopback0
*Mar 1 00:31:47.863: IP: tableid=0, s=192.168.66.6 (Loopback0), d=202.96.128.14
3 (Ethernet0), routed via FIB
*Mar 1 00:31:47.867: IP: s=192.168.66.6 (Loopback0), d=202.96.128.143 (Ethernet
0), g=192.168.66.66, len 70, forward
*Mar 1 00:31:47.867: IP: tableid=0, s=192.168.66.6 (Loopback0), d=202.96.128.68
*Mar 1 00:31:47.867: IP: s=192.168.66.6 (Loopback0), d=202.96.128.68 (Ethernet0
Purple
Out of curiosity, is there another box that you are connecting to that is NAT'ing the 192.168.x.x addresses to public addresses ? If not, the problem could be that the internet destinations you are going to cannot route back to you since your addresses are from the private address range.
Hope that helps - pls rate the post if it does.
Paresh
oh,sorry, I donn't say it clearly,I make the configuration in my intranet ,
the topology is show below:
my pc--->switch-->firewall -->router----->internet
teset router
the above configuration is on the test router, That firewall left is private IP address ,right is public IP address .
sorry,the topology above is a bit wrong ,my pc and the test router is all connected to the internal switch ,,,
hehe
thank you !!!
144
