A VoIP call be drop,ISDN Disconnect Cause Codes is "Temporary failure"
ccnarick
When I initial a call form remote site(Phone1). Phone1--PSTN1 -->T1(E&M)-->VoiceGW1------>VoiceGW2-->ISDN-PRI-E1-NET5-->PSTN2--Phone2
The call disconnect and get ISDN Q931 messages "TX --> DISCONNECT" and Disconnect Cause Codes is "Temporary failure" in VoiceGW2 after connect 15sec.
But when I initial a call from local(Phone2) to remote is OK.
Felipe Garrido
There may be a negotitation issue between VGW1 and VGW2. Are they communication via H.323 or SIP?
If H.323, collect the following debugs,
From VGW1,
debug voip ccapi inout
debug vpm signal
debug h225 asn1
debug h245 asn1
debug ip tcp transaction
debug h225 q931
From VGW2,
debug isdn q931
debug h225 asn1
debug h245 asn1
debug h225 q931
If SIP,
From VGW1,
debug vpm signal
debug ccsip message
From VGW2,
debug isdn q931
debug ccsip message
Please also include the following output from each gateway,
show version
show run
show voice dsp detail
show voice dsp group all
show voice call summary
show diag
-Felipe
pls see attache files.
Looks as though not all the debugs were collected. I don't see the output of "debug ip tcp transaction" it looks like the TCS from GW1 is not making it to GW2. This causes media negotiation to fail. Is it possible to get a packet capture of the call off of the GW2?
-Felipe
