AA configuration issue with CME 3.3
I have a router with 2 port FXO card having an analog PSTN line terminated on one port. The number is 24785780. I have assigned this number to the AA. But I cannot get the AA work. when I dial the AA number, I get an dial tone and then after a few seconds I get a busy tone. Before the busy tone, if i dial any internal ip phone DN, the ip phone rings. But I cannot get the AA script to work.
I have attached the working config and also the debug .
Any advice on the same ?
Brgds
renzil
Re: AA configuration issue with CME 3.3
Remove the incoming called number and only specify,
dial-peer voice 1 pots
port 0/0/0
service aa
See if this helps!
Thanks for the suggestion, but it does not work.
The same problem. when I dial the AA number, I get a dial tone for a few seconds and then a busy tone.
From the debug, I notice that the called number i.e the AA number does not display. Can this be a issue ??
Brgds
Renzil
hi
how did you configure your application?
i done a dial-peer voip like this one:
dial-peer voice 100 voip
incoming called-number
destination-pattern
application aa
session target ipv4:< IP@ of the router>
codec G711ulaw.
See if it can help you
Eric, Like indicated in the original post. the application command has been deprecated in newer IOS and is replaced by service command.
1) Under voice-port 0/0/0 configure "connection plar 24785780. This will provide the DNIS that IOS will use to match the inbound dial-peer 2. It will match dnis using "incoming called 24785780". FXO cannot provide DNIS, only ANI. So you have to provide it.
2) Configure direct-inward-dial on dial-peer 2. This is why you are getting the second dial-tone inbound.
You can prove it this way: if, when you get that dial-tone, you enter the dnis, the application should then start.
Thanks michael,
I do get the DNIS info now, but yet the application does not work. I get a fast busy tone when i call the AA number.
Attached is the log file. Any more debug that can be helpful to solve the issue ?
Thanks for your time.
Brgds
Renzil
I just downloaded the the acd application and readme that comes with it.
Let's start with a "debug voip dialpeer all" to make sure we are hitting the application, then a "debug voip ivr script" to see what errors it is seeing. I suspect that it is looking for some ephone-hunts for the acd portion of this, but I'm not sure. Hopefully the debug will tell us more.
I am attaching the readme because there is a lot of information that should be reviewed and understood for this application.
I haven't used this particular flavor of aa before, but I am very curious. I'm gonna lab it up tonight (CST) and see what I can come up with for you.
Were you able to pull any of those debugs?
hi Michael,
thanks for your assistance. I added some hunt groups to the config. I yet get the busy tone. Attached is the debug u mentioned.
Brgds
renzil
So from the debug voip dialpeer all out put, we see call coming in on dial-peer 1
Sep 15 07:46:59.325: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=1
and hairpinning out to dial-peer 1.
Sep 15 07:46:59.337: //-1/BAF709488079/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=1
I would first remove the "port 0/0/0" from dial-peer 2.
Then if it fails, you should get output from "debug voice application error, to see if aa is really running.
Hi Michael,
can u advice on the attached debug.
Renzil
I am also facing the exact problem which you are facing.
Did every part base on the documentation but still not greeted by the welcome prompt.
Any workaround? Am using CME3.3 IOS ver 12.4(3)
Bronze
hi,
here is a config that goes for me:))
additionally i have 1 queue in my config.
IOS Version: 12.3.14T2
greetings
mehmet
voice translation-rule 10
rule 5 /^$/ /98765000/
voice translation-profile INCOMING
translate called 10
application
service aa-basic flash:app-b-acd-aa-2.1.0.0.tcl
paramspace english index 0
param second-greeting-time 0
param welcome-prompt _PrivatWelcome.au
paramspace english language en
param call-retry-timer 1
param max-time-call-retry 900
param voice-mail 61
param service-name basic-queue
param number-of-hunt-grps 3
param handoff-string aa-basic
param dial-by-extension-option 1
paramspace english location flash:
param max-time-vm-retry 1
param max-extension-length 3
param aa-pilot 98765000
service basic-queue flash:app-b-acd-2.1.0.0.tcl
param aa-hunt2 60
param queue-len 10
dial-peer voice 1001 pots
service aa-basic
incoming called-number .
direct-inward-dial
port 0/0/0
voice-port 0/0/0
translation-profile incoming INCOMING
Mehmet,
Thanks for the heads up, I got it working finally. Realise that I missed out the "param voice-mail" command. Not knowing that it was mandatory since I wanted to try the feature out without CUE.
Cheers..
hi,
When i apply the service aa-basic application iget the below message like
Warning: parameter aa-pilot has not been registered under aa-basic namespace
CCME-ROUTER(config)#
CCME-ROUTER(config)#app
CCME-ROUTER(config-app)#service aa-basic flash:app-b-acd-aa-2.1.0.0.tcl
CCME-ROUTER(config-app-param)#paramspace english index 0
CCME-ROUTER(config-app-param)#param second-greeting-time 0
Warning: parameter second-greeting-time has not been registered under aa-basic namespace
CCME-ROUTER(config-app-param)#param welcome-prompt en_bacd_welcome.au
Warning: parameter welcome-prompt has not been registered under aa-basic namespace
CCME-ROUTER(config-app-param)#paramspace english language en
CCME-ROUTER(config-app-param)#param call-retry-timer 1
Warning: parameter call-retry-timer has not been registered under aa-basic namespace
CCME-ROUTER(config-app-param)#param max-time-call-retry 900
Warning: parameter max-time-call-retry has not been registered under aa-basic namespace
CCME-ROUTER(config-app-param)#param voice-mail 200
Warning: parameter voice-mail has not been registered under aa-basic namespace
CCME-ROUTER(config-app-param)#param service-name basic-queue
Warning: parameter service-name has not been registered under aa-basic namespace
CCME-ROUTER(config-app-param)#param number-of-hunt-grps 2
Warning: parameter number-of-hunt-grps has not been registered under aa-basic namespace
CCME-ROUTER(config-app-param)#param handoff-string aa-basic
Warning: parameter handoff-string has not been registered under aa-basic namespace
CCME-ROUTER(config-app-param)#param dial-by-extension-option 1
Warning: parameter dial-by-extension-option has not been registered under aa-basic namespace
CCME-ROUTER(config-app-param)#paramspace english location flash:
CCME-ROUTER(config-app-param)#param max-time-vm-retry 1
Warning: parameter max-time-vm-retry has not been registered under aa-basic namespace
CCME-ROUTER(config-app-param)#param max-extension-length 3
Warning: parameter max-extension-length has not been registered under aa-basic namespace
CCME-ROUTER(config-app-param)#param aa-pilot 300
864
