Community Member
AAR with call forward and busy
I have two sites A and B setup with AAR. If A calls B and there is no bandwidth AAR works fine. However if user B setup call forward or busy to another phone AAR does not work at all. All I get is a quick beep on B and A get disconnected. Is this a bug or limitation of AAR?
CM is 3.3.4
Re: AAR with call forward and busy
I will test this in lab here soon. The version I will test this on is 3.3.3. Are you CForwarding from B to A via the 4 digit extension ? Have you set AAR prefixes or external phone number masks on the phones properly ?
Sankar
PS: please remember to rate posts!
Highlighted
Community Member
Yes I call from A to B, but on B phone I set the call forward and busy to reception. Phone B is onhook. I have set all the parameters correctly because phone B will work if I take out CFD and Call Busy.
Community Member
Call phone B internally set callforward and busy to reception and check whether its working or not it can be an issue partition and Calling Search Space.
Community Member
Any luck on getting this tested on the labs?
149
