About 7950 IP Phone and 3550 Switch
Can anyone help me?
In case of that 7950 IP phone is connected to a 3550 switch, which configuration would be correct?
Config#1
SW-1 :
vlan 200
name VOICE
mls qos
interface FastEthernet 0/7
switchport mode trunk
switchport voice vlan 200
switchport trunk native vlan 11
Config#2
SW-1 :
vlan 200
name VOICE
switchport mode access
switchport access vlan 11
I think, Config#1 sets all cos value on the switch to 0 by enabling mls qos. So if voice traffic set with another cos value could not be assured even can't flow.
In case of Config#2, I think it would work fine. No change would be made in the voice and data traffic.
Your opinion would be valuable.
Cheers
Hall of Fame Super Silver
Re: About 7950 IP Phone and 3550 Switch
Both configuration will do the same thing, the prefered, newer way is the second config, I'd recommand adding spanning-tree portfast to it. Also, since you enabled QoS on the switch but did not establish trust bundry on the switchport all of the traffic will be remarked down to COS/DSCP 0. You need to add the following:
"mls qos trust device cisco-phone"
"mls qos trust cos"
also, add the following command under the uplink to the router"
"mls qos trust dscp"
HTH, please rate all posts!
Chris
Hall of Fame Super Gold
I think it is correct, basically with qos enabled, by default you give equal precedence to all traffic, and need to specify policies to classify traffic in queues different than 0.
You would need however severe egress congestion to get potential trouble.
BTW, what is a 7950 phone ?
1314
