07-07-2003 05:12 PM - edited 03-13-2019 12:37 AM
I want to upgrade the CM version from 3.1 to 3.3. I don't have the upgrade kit.
I want to reinstall the callmanager. but I hope to keep the old data. Can I backup the old data in CM ver 3.1 and restore to CM ver 3.3 ?
07-07-2003 11:40 PM
you can backup data in CM 3.1 and restore to CM 3.3 using a version of the MCS backup utility that is compatible to both versions (3.5.6 and above). You can download it from CCO. But you certainly need the upgrade kit for the upgrade...
Y.
07-19-2003 01:33 AM
HI
If I use different Version About the Utility Of CM Backup Which is above 3.5.6. Can i Backup and Restore in different Version.
07-19-2003 02:47 AM
The fact that you can upgrade from 3.1 to 3.3 depends on the version that you have as callmanager. Have a look at the compatibility guide:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/ccmcomp.htm
If you are running a supported version then you can do the upgrade. The upgrade is done by taking a backup of the existing data, installing the 3.3 version and then importing the data back into the CCM. The backup utility that needs to be used needs to be at least 3.5.18 but can be 3.5.6. More info on the upgrade to eg 3.2 can be found at
Kind Regards
Ullie Versavel
Cisco Support Engineer
07-22-2003 07:37 PM
HI
I will Upgrade the CM from 3.1(4b) to 3.3(2). My hardware is MCS-7835-1266. The harddisk performance is Mirror function. I want to save the old data to forback if the Upgrade is unsccessful. May I take a harddisk out from sdlot 1 and then upgrade ????
