Silver
about cme 4.x, SIP softphone and g729
Hi folks,
it's normal that a x-lite softphone (mac os x version) registered on CME 4.x system:
- calls correctly all internal numbers (ip phones Cisco)
- the client supports only g711a/u, GSM, iLBC and SPX ... then it uses g711a/u ... but all dial-peer voip use g729, then when I try to call a voip number, cme try to connect that with dial-peer pots, and it doesn't work ... no way to do that? I could only:
1- change dial-peer voip codec to g711
2- change softphone with g729 support
any advice will be appreciated
Andrea
196
