Accepting incoming calls w/VG200 and CallManager
Good morning, I currently have a VG200 with 4 FXO ports connected to 4 POTS lines. I am able to place calls using my Cisco 7940 IP Phones through the outside POTS network and place interoffice calls between the extensions. I am unable to recieve calls though. Whenever I call one of the lines hooked up to the VG200, it rings once and then gives a dial tone which you can then dial out from. I would like it to send the incoming calls to my Call Manager and ring on all my phones. Please help, thanks in advance!
Dan Brummer
Re: Accepting incoming calls w/VG200 and CallManager
It looks like that your router config is not good. your config should be like this.
voice-port 1/0/0
no comfort-noise
connection plar 2000
voice-port 1/0/1
no comfort-noise
connection plar 2001
voice-port 1/1/0
no comfort-noise
connection plar 2002
voice-port 1/1/1
dial-peer cor custom
dial-peer voice 1 pots
destination-pattern .T
port 1/0/0
forward-digits all
dial-peer voice 2 pots
preference 1
port 1/0/1
forward-digits all
dial-peer voice 3 pots
preference 2
port 1/1/0
forward-digits all
dial-peer voice 69 voip
incoming called-number .
destination-pattern 2...
session target ipv4:10.69.99.2
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
The connection plar 2000,2001,2002 ... should be the number on your IP PHONE, when calls comes in than call manager will route the callt omain phone line on your IP PHONE. than in your call manager you can configure to ring on all phones.
Rakesh
I shouldn't be too worried with 'destination-pattern .T ' correct? Also would:
codec g711ulaw
no vad
Apply to my application? Thank you for your response!
Dan
You should not be worried for destination pattern. But you should have the Dail-peer so that in comming calls can be routed to Call manager i.e.10.69.99.2 in this case.
No luck, below is my configs. What's happening is I'm calling the POTS number that's plugged into voice port 1/0/0 with my cell phone, it rings once, then gives a dial town.
voice-port 1/0/0
output attenuation 0
echo-cancel coverage 16
application mgcpapp
port 1/0/0
forward-digits all
dial-peer voice 100 voip
incoming called-number 360xxxx (Phone number for POTS line)
session target ipv4:10.1.1.2
I have DirN 2000 setup as a Pilot Point in call manager. Is there any other way to get a DN that sends to all phones? Thanks, Dan.
104
