Accidently the default two direct routing rule were deleted
Accidently the default two direct routing rule were deleted. I just recreated them back as before. Will this have any potential problem? I think as long as the attempt sign in is there, should be OK, then I can add whatever greeting bellow that. Right?
1 REPLY
Re: Accidently the default two direct routing rule were deleted
That should work, or if you want the exact rules in there you can have them rebuilt autmatically by running configmgr.exe from the commserver directory, and select the run rules configuration script. I do not believe that this wipes out any rules,but I would do a dirt backup first just to be sure.
steve
98
