ACS_CALL MANAGER INTEGRATION
Please can someone help me with this: is there a possibility of integrating the ACS server_ with Call MANAGER 6.1 .Want team members to use their Domain LOGIN credentials to authenticate into the Call manager.
thanks
Re: ACS_CALL MANAGER INTEGRATION
Not possible, you would need to integrate CUCM to your LDAP for that.
java
if this helps, please rate
www.cisco.com/go/pdi
Hi Jaime,
Can you please put me through on how to achieve the CUCM - LDAP integration if possible suggest a material that can guide me.
Thanks.
The CUCM administration guide has all such info, look it up on CCO, or just use the online help from the server.
Go to the LDAP pages and use help -> for this page
java
607
