Active association question on ICM with Avaya
Does anyone know of an easy way to determine the Active Association volume on an ICM PG connected to an Avaya? I looked at the help file here and it tells you to dump the pim log to see if you see a particular message stating that you've exceeded the active association maximum. However, I'm unaware of a way, either on the Avaya or on the PG, to determine how close you might be before going over the limit. In other words, a way to check and prepare for when you might be approaching that limit. Any suggestions?
Re: Active association question on ICM with Avaya
The problem with that FAQ is that while it gives good guidelines about active associations, it doesn't tell you a specific command, either on the PG or Map-D, of how many active associations are active at any one moment, or even historically, unless you go over the limit.
http://www.cisco.com/c/en/us
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/icm-peripheral-gateway/49542-asai-on-avaya-pg.html
355
