Community Member
Add prefix on IP GSM gateway call
Hi I have a problem with my dial plan
I have a call manager on Cisco 3745 and Cisco IP phone and call and call is OK
I also have an IP GSM gateway, and I need to add prefix on all outgoing GSM call
For example if GSM number is 9002256 or 6220088, I need user to dial 4049002256 or 4046220088, the CME remove the prefix and forwarded cal to IP GSM gateway only with the real phone number: 9002256 or 6220088
For GSM incoming call, all incoming call should be forwarded to the standard user
I tried this configuration
telephony-service
call-forward pattern 9......
call-forward pattern 6......
calling-number local
transfer-system full-consult
transfer-pattern 9......
transfer-pattern 6......
dial-peer voice 6000 voip
corlist outgoing call2
session protocol sipv2
session target ipv4:10.6.3.8
dtmf-relay sip-notify
destination-pattern 4046......
dial-peer voice 9000 voip
destination-pattern 4049......
But it doesn't work.
How can I make sure that CME remove the prefix 404 and send only 9...... or 6...... when he forward call to the Ip GSM gateway?
Thanks in advance for your help
Hall of Fame Super Gold
Re: Add prefix on IP GSM gateway call
voice translation-profile strip404
translate called 404
voice translation-rule 404
rule 1 /^404/ //
destination-pattern 404[69]......
translation-profile strip404 outgoing
no dial-peer voice 9000 voip
Community Member
ok, thanks
please what is the command to view all the log process of incoming or outgoing call, during the call
203
