Adding a Remote site
we have a set of callmangers at our main site.
We have ordered an ISDN 30 to a remote site which connects to a 3560.
This remote site will use our callmangers and using the link to main site (new isdn 30) will make calls out of our gateway.
I have a few questions that I hope some one can clarify
1) on the new 3660 to make sure all voice traffic goes out that link do I just use a default route? and where do I point it?
2) as I am using mgcp I don't have to configure any dial plans, but if I was using h323, for voip calls I would use session target to callmanger but how would I set up externall calls as these still need to go through mail link
3) on the callmanger do I configure the new isdn link as a trunk point it at the ip address of the new router ? then add route patterns matching the DDI range to use that trunk?
finaly the site also needs SRST so does that mean they have to have a pstn connection at site?
Thanks in advance for helping me with my confusion.
1 REPLY
Re: Adding a Remote site
- Are you goign to use this 3660 to connec the main site and remote site or you ar eogint o use it as a Gateway?
- If it is used to connect the two sites, proper routing & QoS needs to be configured
- If You ar eusign MGCP you shoudl eb fine
- You will addthis as a gateway in the Call manager.
For outgoign calls you can creat a route pattern which will use this gateway>RoutList>Route group
95
