Adding Mobile Numbers and other numbers at Corporate Directory
During the integration between LDAP, and CCM, only one field redarging the directory number can be imported. I want to import other directory number (Mobile, Home, ...)
How can i do this.
Regards.
Re: Adding Mobile Numbers and other numbers at Corporate Directo
callmanager version??
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
The corporate directory in the CCM isn't really extensible. You're probably better off attaching to another data source that fits your needs or use / create a directory that combines multiple data sources (e.g. get the internal phone numbers from the ccm and the rest from your AD - if you use the windows login as username matching records won't be a problem).
288
