Additional Speed Dial options for 7960/40
Hello:
Are there any products that can expand the number of speed dials on the 7900 series for office use??
Re: Additional Speed Dial options for 7960/40
check out this site:
http://www.voip-tools.org/index.php?option=com_content&task=view&id=56&Itemid=85
It's a GUI inteface for speedials, etc and it's free!
If you want to get really fancy, Citrix has a product call Application Gateway that uses a function called "Click to Call" which i think is coming out in CCM 5 anyways, but this pretty slick also.
thank you very much
How many do you need? There are 99 total for the phone - the ones assigned to the line buttons and the rest of the 99 are abbreviated dials. So if I'm on hook I press 99 then the AbbrDial softkey and the call goes out to the dial string assigned to slot 99. I then also have 99 FastDials, and on top of that the Personal Contacts service that I can use. There's also Web Dial and Directories.
Don
Don, Could you point me to a link the shows how to configure a 7940/60 for Speed Dial...I would like to press, say line 2 and the line automatic dial 9-1-214-555-1234.....Thanks Man!!
Hall of Fame Super Red
Hi Jack,
Here you go!
Configuring Cisco IP Phone Speed Dial Buttons with CallManager 3.3x and 4.x
From this good tech note;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094765.shtml
Hope this helps!
Rob
163
