Adjusting volume with Music on Hold
This is my first install of MOH and am looking for a way to turn up the volume..can anyone help on this?
1 REPLY
Re: Adjusting volume with Music on Hold
If you are using a fixed audio source then you can try uping the volume on the mic or the line input depending on which one you are using. If you are using mp3 or wav files I am not sure what you can do other than trying to record them in a louder volume.
Hope this helps,
-Mckee
284
