Community Member
Admin Password problem after ES upgrade.
While using Cm 3.2.2c and upgrading to ES 2.2.3.b I have lost access to CCMAdmin/main.asp Instead of getting the standard login pop-up window, I now get a web based Administrator access window and it does not recognize my admin password. When I try other valid "users" it tells me that they do not have admin access (which they shouldn't) But I do not know why it does not recognize my admin password. TAC has had me reset the passwords in the services as well as re-installing the +COM services but this has not solved the problem. Does anyone know how to get this password reset? Oddly enough the same login/password works for BAT and Win 2k and SQLSvc (the Subscriber is getting updated) Thanks in advance.
Community Member
Re: Admin Password problem after ES upgrade.
you must of installed multi level admin .
you should logon as ccmadministrator and enter your password .
let me know if this works
jkoniecki@yahoo.com
Community Member
Perfect!!! Now how come TAC didn't catch that? I havn't used the Multilevel Admin feature before. How will this affect other login features? Do I have to change anything on the Subscribers?
Thanks for your help.
Community Member
Glad it worked
Now remember this .. STi backup does not back up the MLA as of yet . I can not locate the doc on cco but i know it exists .
email me for the pdf
Jkoniecki@yahoo.com
Also - MLA must be reinstalled after applying a CallManager upgrade.
101
