AIM/CUE not Picking-up in-bound external calls
I have a 2811 router with an AIM/CUE (12-VM) card. All of the telephony-service stuff works fine:
-All calls in house work fine
-All outbound calls work fine, to PSTN
-All inbound calls work fine, from PSTN
-Each phone can access it's VM internally
-the CME gui and the Unity-Express gui's are accessible on the LAN.
But, when I call from outside into the PRI with a DID number, I get four rings, then a pause, and then it never goes to voicemail. Sometimes; depending if I call with my celr or a land line, I get the message "Sorry your call cannot be completed as dialed, 000-000." Any clue why the vm does work for internal or external calls.
Here's a sample of the config.
interface FastEthernet0/0
no ip address
no ip mroute-cache
duplex full
speed 100
interface FastEthernet0/0.100
description SUB-IF for VOICE VLAN
encapsulation dot1Q 100
ip address 10.1.100.1 255.255.255.0
interface FastEthernet0/0.101
description GW FOR VOICEMAIL MODULE AIM/CUE
encapsulation dot1Q 101
ip address 10.1.101.1 255.255.255.0
interface Service-Engine0/1
discription AIM/CUE VOICEMAIL MODULE
ip unnumbered FastEthernet0/0.101
service-module ip address 10.1.101.2 255.255.255.0
service-module ip default-gateway 10.1.101.1
ip route 10.1.101.2 255.255.255.255 Service-Engin0/1
dial-peer voice 40 voip
description ** cue voicemail pilot **
destination-pattern 6000
session protocol sipv2
session target ipv4:10.1.101.2
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 41 voip
description ** cue auto attendant **
destination-pattern 6001
codec g711ulaw
no vad
dial-peer voice 1 pots
description ** T1 PRI Emergency 911 **
destination-pattern 9911
port 0/0/0:23
forward-digits 3
dial-peer voice 2 pots
description ** T1 PRI OutBnd Calls **
destination-pattern 9T
port 0/0/0:23
dial-peer voice 3 pots
description ** T1 PRI InBnd Calls**
incoming called-number .
direct-inward-dial
port 0/0/0:23
  • Other Collaboration Voice and Video Subjects
Re: AIM/CUE not Picking-up in-bound external calls
How many digits is telco sending you?
Can you attached the following debug's
debug voip ccapi inout
debug isdn q931
Place a inbound call and see how many digits are being passed. And what dial-peer the router is taking.
The telco is pasing all 10 digits, at least that's what I see when a call comes in-bound to one of our DIDs/phones. I can do the dubug on thurds since i'm out sick today and tomorrow. Thank You for the response, I will repost with the debug info on thurs.
By the way, here is a copy of my telephony-service. Thanks.
telephony-service
load 7910 P00405000700
load 7960-7940 P0030702T023
max-ephones 20
max-dn 20
ip source-address 10.1.100.1 port 2000
auto assign 1 to 20
system message SSP
dialplan-pattern 1 6503926... extension-length 4
voicemail 6000
max-conferences 8 gain -6
call-forward pattern .T
moh music-on-hold.au
transfer-system full-consult
secondary-dialtone 9
create cnf-files version-stamp 7960 Jul 12 2006 10:45:43
ephone-dn 3 dual-line
number 6172 secondary 6503926172
label 6172
description Mina Hinojales
name Romina Hinojales
call-forward busy 6000
call-forward noan 6000 timeout 10
no huntstop
Problem has to do with how many Digits are getting sent to voice mail on the router when it tries to make the call. You should be seeing 10 digits in the debug.
Next question when one ephone calls another ephone locally does voice mail work?
Try the following commands. This will create a translation-rule that will strip incoming 10 digits to the 4 digits you need. I assume you do not need all 10 digits.
voice translation-rule 1
rule 1 /^650\(....\)/ /\1/
voice translation-profile digitstrip
translate called 1
voice-port 0/0/0:23
translation-profile incoming digitstrip
*************Voice port were you Telco Line comes in Port 0/0/0:23 based on your config*************
telephony-service
no dialplan-pattern 1 6503926... extension-length 4
Ronnie
Link to translation rules. If you get bored and want to do some reading.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
No, the VM does not kick-in even between internal ephones. That translation rule you sent me should do the job, i'll try it on thurs.
Thank You Very Much,
Can I use a translation rule on the sip dial-peer instead of for the entire router? In other words, when I remove the dial-pattern command in tele-service I loose the caller-id on all outbound calls. If I make a translation rule to translate all inbound e164 numbers to the VM AIM-CUE, and then apply the rule to the sip dial-peer, will this work better? Or is it just easier to make my VM boxes 10-digits (the same as my DIDs/e.164 numbers) instead of 4 digits?
You can add tranlation rules to Voice-Ports, VOIP dial-peers and Pots dial-peers which ever you prefer.
You could add the rule to the sip peer and test it. I don't have a router in front of me to test it. You could also change your VM boxes to 10 digits.
But the quick and easy solution would be add another translation rule to handle outbound digit insertion.
I assume your internal DID block starts with a 6...
voice translation-rule 2
rule 1 /^6/ /6503926\1/
voice translation-profile clid
translate calling 2
voice-port 0/0/0:23
translation-profile outgoing clid
This will now add digits to your outbound calls.
392
