AIM flash
Hi All;
what command is used to see the contents (files) in the flash memory of AIM-CUE?
thanks
Alex
Re: AIM flash
There is no "show flash" equivalent in CUE CLI. You can however use the following commands to see the configuration, scripts, and prompts stored in flash.
service-module service-engine interface number session
sh start
sh ccn prompts
sh ccn scripts
Hope this helps. If so, please rate the post.
Re: AIM flash
Hi;
for example I download license file from FTP to CUE. How should I make sure that file is in flash memory?
thansk
Alex
Re: AIM flash
You can issue a:
show software licenses
to view the license that is currently installed on the cue module.
130
