Silver
AIM-Voice-30
Does anybody know if AIM-Voice-30 + VWIC -1MFT-E1 when working with PBX or PSTN using ISDN-PRI Is unctionally similar to NM-HDV-E1?
Thanks in advance
Marina
Re: AIM-Voice-30
Marina,
For the most part PBX/PSTN intergration is similar between the two, however there are some exceptions. For example, the AIM-Voice-30 doesn't currently support high complexity codecs (the NM-HDV does).
For more information on the AIM, checkout:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122limit/122x/122xb/122xb_2/ft_gins2.htm
For more infor on the NM-HDV, check out:
http://www.cisco.com/warp/public/788/products/hdv_netmod.html
By the way, the VWIC-1MFT-E1 is the same adapter that is used in the NM-HDV module to make it an NM-HDV-E1. In the case of the AIM-Voice-30, it's basically providing the DSP resources just like the NM-HDV PDVM does.
Jordy
Silver
Re: AIM-Voice-30
127
