Community Member
Analog phone via built-in FXS port?
We currently have a Cisco CallManager Express implementataion with a 2811 router, 4 built-in FXS and 4 FXO ports, and (5) 7960 IP phones. We would like to use a standard cordless phone for manager only usage early in the morning.
We connected the phone to the first FXS port and are able to dial out and make calls properly as per the dial-peers that are already configured. We would like to configure this FXS port so this analog phone could function similar to an IP phone (answering incoming calls, possibly transfer and on-hold functions).
I've read the CCME admin guide and the guide on voice ports, but I'm having trouble with the solution. I understand that it needs to be configured as an ephone, but how do I configure the ephone to point to the FXS port? Or am I way off base?
Thanks in advance!
Blue
Re: Analog phone via built-in FXS port?
try this....(change some settings as they pertain to your environment)
router(config)# ephone-dn 1 dual-line
router(config-ephonedn)# number 2500
router(config-ephonedn)# label user1
router(config-ephonedn)# call-forward busy 2599 (2599 can be voice mail, etc)
router(config-ephonedn)# call-forward noan 2599 (2599 can be voice mail, etc)
router(config)# ephone 1
router(config-ephone)# username user1
router(config-ephone)# mac-address xxxx.xxxx.xxxx (mac of your phone)
router(config-ephone)# type 79xx (type of ip phone in use)
router(config-ephone)# button 1:1 (assign ephone-dn 1 to button 1)
router(config)# voice-port 1/1/0
router(config-voiceport)# no shut
router(config-voiceport)# connection PLAR 2500
router(config-voiceport)# port 1/1/0
also, see this link for more info:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00804ad863.html
Silver
Analog phones are a little different, especially connected to fxs ports:
Analog Phone Support Restrictions
•Cisco Unified CME features such as call forward and call park are not available for analog phones connected to FXS ports in H.323 mode. In order to support these features, SCCP supplementary features must be enabled on the FXS ports. For information about SCCP supplementary features, see the "Analog Phones" section on page 138 and the Cisco Unified CME data sheet.
FXS ports on platforms that cannot enable SCCP supplementary features can use H.323 mode to support call waiting, caller ID, hookflash transfer, modem pass-through, fax (T.38, Cisco fax relay, and pass-through), and PLAR. These features are provisioned as Cisco IOS voice features and not as Cisco Unified CME features. Note that when using Cisco Unified CME, you can configure FXS ports in H.323 mode for call waiting or hookflash transfer, but not both at the same time.
The following links provide information on analog phone features for FXS ports in H.323 mode:
– "Configuring Analog Voice Ports" section in the Voice Port Configuration Guide
–" Caller ID" section of the Cisco IOS Voice Configuration Library
– Cisco IOS Fax and Modem Services over IP Application Guide
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00805c69d8.html#wp998550
The easy answer it to put the phone on an ATA instead of an fxs port.
Mary Beth
Community Member
Well, what if I didn't care about the special features...what if I just wanted to allow someone to dial out and answer incoming calls with the analog phone connected to the FXS port?
The phone can already dial out using the dial-peers in place...but I would like the analog phone connected to the FXS port to be able to answer incoming calls? Basically, how do I make it ring when a call comes in?
Community Member
Ok, so I already have this on my FXO ports:
voice-port 0/0/0
supervisory disconnect anytone
connection plar opx 150
description FXO-xxx-xxx-xxxx
station-id name Outside Line
voice-port 0/0/1
connection plar opx 151
voice-port 0/0/2
connection plar opx 152
And this as a dial-peer for my FXS port:
dial-peer voice 400 pots
description Cordless Phone
destination-pattern 160
port 0/1/0
I would remove that and make a dial-peer such as this:
destination-pattern 150
port 0/1/0
And any calls coming in on my first FXO port would also ring my analog phone on the first FXS port? (allowing someone to answer using the analog cordless phone if they are not near an IP phone)
Is that correct? Or, does the destination-pattern just signify the extension number of the phone on the FXS port?
Thanks for all the help by the way!
Community Member
Here is a sanitized config from the router:
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
description FXO-Unused
voice-port 0/1/0
station-id name Cordless Phone
caller-id enable
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
dial-peer voice 201 pots
preference 3
destination-pattern 91..........
port 0/0/1
forward-digits 11
dial-peer voice 202 pots
preference 2
port 0/0/2
forward-digits 11
dial-peer voice 200 pots
preference 4
port 0/0/0
forward-digits 11
dial-peer voice 100 pots
preference 4
destination-pattern 9[2-9]......
port 0/0/0
forward-digits 7
dial-peer voice 101 pots
preference 3
port 0/0/1
forward-digits 7
dial-peer voice 102 pots
preference 2
port 0/0/2
forward-digits 7
dial-peer voice 300 pots
preference 4
destination-pattern 9T
port 0/0/0
dial-peer voice 301 pots
preference 3
port 0/0/1
dial-peer voice 302 pots
preference 2
port 0/0/2
description Local FAX on router
port 0/1/0
telephony-service
load 7910 P00403020214
load 7960-7940 P00305000600
max-ephones 36
max-dn 144
ip source-address 192.168.10.254 port 2000
create cnf-files version-stamp Jan 01 2002 00:00:00
max-conferences 8 gain -6
moh music-on-hold-1.wav
multicast moh 239.1.1.1 port 2000 route 192.168.10.254
transfer-system full-consult
secondary-dialtone 9
ephone-dn 1
number 150
label Line-1
description Outside Line 1
hold-alert 30 shared
ephone-dn 2
number 151
label Line-2
ephone-dn 3
number 152
label Line-3
ephone-dn 100
number 100
label location0 100
description xxx-xxx-xxxx
name Office
ephone-dn 101
number 101
label location1 101
name location1
ephone-dn 102
number 102
label location2 102
name location2
ephone-dn 103
number 103
label location3 103
name location3
ephone-dn 104
number 104
label location4 104
name location4
ephone-dn 105
number 105
label location5 105
name location5
ephone 1
type 7960
button 1:100 2:1 3:2 4:3
ephone 2
type 7960
button 1:101 2:1 3:2 4:3
ephone 3
type 7960
button 1:102 2:1 3:2 4:3
ephone 4
type 7960
button 1:103 2:1 3:2 4:3
ephone 5
type 7960
button 1:104 2:1 3:2 4:3
ephone 6
type 7960
button 1:105 2:1 3:2 4:3
Silver
Yes, an incoming call that hits that fxo port will plar to ext 150 - which would be that fxs port, unless you happen to have an IP phone that also has that number on it, in which case it totally ignores the destination pattern on the fxs port. It you have new enough software, I think cme 3.4, it actually will give busy if you try to share the line, but with older stuff, it at least rings the ip phone. I just went through this, worked with TAC because we could not believe it was true, but we had not actually tried it before. Can duplicate in our lab, too. If you need to share the line with an ip phone, you have to get SCCP controlled analog line, like ATA.
Mary Beth
Silver
Looking more carefully at what you posted, yes the dial-peer with the destination pattern of 150 would be the way to ring that fxs port, but it looks like you also have ephone dn with that number, so IP phone is using it, and as I mentioned before, that will not work. You could remove the ephone dn and put in the dial peer and test that you port rings, but it looks like you already have a fax taking calls, so you know that works, it is the sharing that will not work, and would require something like an ATA.
Mary Beth
1476
