Analogue Modems connected to Cisco equipment
I am currently spec'ing a Call Manager solution.
However, I can't find a definitive answer to determine if its possible to connect modems to analogue ports on a 3600, 4000 or 6000.
The customer currently has dedicated PSTN lines for this but would obviously like an intergrated solution.
Any ideas if/which cards will support this?
thanks
Mark.
Re: Analogue Modems connected to Cisco equipment
How many PSTN's have you got to hook up and are they for fax or data, if the later what speeds are they currently running at?
They have approx 3-4 fax and modems at each location (8 offices). The modems are various types running at V34 or V90.
Using the latest loads for the WS-X6624-FXS blades (A002U300) and the WS-X6608-[T1|E1] blades (D004U300) fax as well as modem has been working pretty well, and at good speeds.
109
СоздатьДля создания публикации, пожалуйста в систему
