Highlighted
Community Member
ANALOGUE VOICE GATEWAY
I HAVE A 24 PORT AVG. OUT OF WHICH I AM CONNECTING A TOTAL OF 10 ANALOGUE SUBSCRIBERS LOCALLY. I NEED TO GIVE CONNECTIVITY TO 10 SUBSCRIBERS LOCATED AT APPROX 5 KMS. OFC CONNECTIVITY IS AVAILABLE BETWEEN BOTH THE LOCATIONS. GIVE ME SUGGESTION ABOUT THE END EQUIPMENT CONNECTIVITY TO CONNECT 10 ANALOGUE TELEPHONES AT REMOTE END USING THE EXISTING OFC MEDIA.
Not applicable
Re: ANALOGUE VOICE GATEWAY
The Cisco VG 224 is a Cisco IOS Software-based high-density 24-port gateway for analog phones, fax machines, modems, and speakerphones within an enterprise voice system based on Cisco Unified CallManager.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/gatecont/ps2250/ps5516/product_data_sheet09186a00801d87f6.html
Community Member
Where are you planning to install VG224?
Easy way installs VG224 at subscriber lactation. Use the RAS opti-mux for Ether connectivity.
119
