Another Softphone problem
I have installed CCM 3.3 and 2 7970G in my houses and they all work well. However, I encounter some problem in softphone installed in my XP SP2 thinkpad. I am unable to dial and pick up the call even though I am able to divert the incoming call from IP Phone to other phone. When I dial, I can’t hear any dial-tone and the softphone does not call my other IP phone. When the IP Phone calls my softphone, I can see the called number but when I click the off-hook button, there is no response and the phone continues to ring. Do I miss any configuration in the callmanager ?
Re: Another Softphone problem
Most winXP with SP2 problems are with the firewall that was added. Try disabling the firewall to see if you still have problems.
I did disable the firewall but it's the same.
Best Regards
Ray
Have you checked your sound card settings / sound card preferences both in windows and in SoftPhone? It seems to me, that SoftPhone is trying to use a different soundcard, than you're speakers are on.
When I was in TAC, I remember hearing something similar to this with Thinkpad.
Do you have a VPN client or something installed and running on the PC - if yes, disable this and then try. The softphone might be trying to use the virtual adapter. Also, if you have dual-nic cards, that might be the issue - check it.
Disable the internal firewall of windows completely. Check the CTI traces to find out more about this.
Lemme know how things go.
107
