Any restrictions for FAX T.38 Transmission in a VoIP/POTS Network?
Hi all,
the Problem is to send a FAX in this scenario:
FAX-POTS>3640-T38>AS5300-POTS>AS5400-T38>3640-POTS>FAX
but in this scenarios it works:
1.) FAX-POTS>3640-T38>3640-POTS>FAX
2.) FAX-POTS>3640-T38>AS5300-POTS>FAX
The Fax Configurations on all dial-peers:
dtmf-relay h245-signal
codec g711alaw bytes 80
fax nsf 000000
fax protocol t38 ls-redundancy 0 hs-redundancy 0
h323 signalling is in use
Could be the problem the connections over several VoIP/T38 Networks???
1 REPLY
Re: Any restrictions for FAX T.38 Transmission in a VoIP/POTS Ne
Strange though, when something similar happened and I could not do anything, by chance I happened to disable and re enable the STP in a couple of the involved switches.....and lo!!! It started working.
233
