Community Member
Appending digits using a translation pattern
I need to build a translation pattern which appends digits to allow users to access SIP paging devices.  The translation pattern needs to be *XX[0-4] and needs to be translated to 2XXX0.  I can easily change the * to 2 by defining the pattern as *.XX[0-4] and setting Discard Digits to Pre-Dot and setting Prefix Digits to 2.  I just can't seem to find a way to append the 0 on the end.
Everyone's tags (1)
1 REPLY
Community Member
Is the issue that you just can't do both at once?
Never tried it but why couldn't you use 2 translations patterns with special CSS's so that the first pattern match
*.XX[0-4] translates to predot discard 2XXX and sends this pattern off to a special route partition that includes a pattern match of 2XXX and translates it to XXXX0 with a CSS that sends the pattern back to the partition that contains the paging devices
595
