Community Member
AS5200 does it supports VOIP?
I have chance to get AS5200 Series with 1 Ethernet, 2 T1/PRI, 48 V.34/terminal lines, 50 serial and
16MB RAM, 8MB Flash for 3,000 USD.
Is it possible to use it as a VOIP gateway, like
AS5300. What are the disadvantages, or I will just spend money for nothing..
Alex
1 REPLY
Community Member
Re: AS5200 does it supports VOIP?
The AS5200 does not support the VFCs(Voice feature Card) like the 5300 does. So if you need a Voice Gateway..the 5200 is a waste.
Brian
170
