AS5300 connect 4 T1/PRI circuit, can indicate special circuit....
AS5300 use 4 T1/PRI to connect CO's PRI circuit.
have 4 different CO.
When I have important customer, can using special ciruit to PSTN, can I indicate 1 PRI to using.
but another can't to use this circuit.
How can I do, which command can use at AS5300.
using incoming number or ...
because I can check it's calling number..
1 REPLY
Re: AS5300 connect 4 T1/PRI circuit, can indicate special circui
Are you doing this in conjunction with a Call Manager or are you just using the 5300? If you are using it with a call manager you can use partitions and calling search space. An example is if you have 2 people. One needs to use pri one. Setup a partition for his 9.@ route pattern and discard no digits in call manager and send the call to the 5300. There you will have a pots dial-peer with a destination pattern 9 and the correct pri port. Set the CSS up on that phone so it can only call that 9.@. For the second user create a different partition with a 9.@ discard predot and prefix and 8. On the 5300 setup a dial-peer pots with destination pattern 8 with the correct pri port. Then make sure that phone can only call the 9.@ with the prefix of 8.
Hope this helps,
110
