AS5300 VoIP Dial-Peer overflow problem
Hi all,
I've got a question on my AS5300. Is it possible to configure the limitation on the no. of calls to a voip dial-peer, once it reach it's limit (let say, 23 calls) then it'll overflow to another dial-peer with another session target ip ?? Looking forward to your kind reply ! Thanks in advance !
2 ACCEPTED SOLUTIONS
Re: AS5300 VoIP Dial-Peer overflow problem
The command you're looking for is "max-conn".
Here's the link to the 12.2 documentation on it:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fvvfax_r/vrf_g.htm#1375153
Wierd part is, most of CCO says this command may be used to limit calls, the doc link says in the intro just calls, but the usage guidlines say its for fax-mail only. But you're free to try :)
Silver
Yes it is using the preference command. Lower the preference, higher the priority.
dial-peer voice 3000 voip
preference 1
max-conn 4
destination-pattern 3...
session target ipv4:10.1.1.1
dial-peer voice 30001 voip
preference 2
session target ipv4:10.1.1.2
In the above case, first dial-peer 3000 will be used and it will send upto 4 simultaneous calls. The 5th call will be sent via dial-peer 30001
Hi pwalenta,
Thanks very much for your advice !!
By the way, would you please explain a bit detail about configuring the overflow between the voip dial-peers ?? Is it using the "preference" command ?? Look forward to your kind reply !!
Silver
preference 1
max-conn 4
preference 2
112
