p21
AS5400HPX not sending SIP calls
I have a AS5400HPX running c5400-ik9s-mz.124-7.bin.
I have a 30 channel PRI connected
I have an asterisk sip server
I can send calls from my asterisk to the AS5400HPX and they goi out over the
PRI fine all works ok
When a call comes in on the PRI and I have a VOIP dial-peer to send it onto
my asterick server it never happens. Ihe ISDN error is "Incompatible
Destination" but yet the dial-peer matches correctly. I did the came setup
on a 2621XM and all worked fine. I even send it a call from another router
on H323 and again it would not forward it to the asterisk server via sip.
Has anyone seen this before
the related config...
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
sip
dial-peer voice 10 voip
destination-pattern 91705598
session protocol sipv2
session target ipv4:X.X.X.X:5060
session transport udp
sip-ua
1 REPLY
97
