ATA 186 and DTMF events
do you know if ATA 186(with sccp) is able to relay DTMF events ? If yes, can you tell which parameters have I to modify ? I tried using the default configuration but it seems not to work.
Marcello Bobba
  • Other Collaboration Voice and Video Subjects
1 REPLY
Re: ATA 186 and DTMF events
An ATA using SCCP will send a Skinny signal to CCM with the dialed digits. Depending on CCM version you have you will see something similar to this in the detailed ccm traces for each keypress:
09/29/2005 07:55:19.195 CCM|StationInit: (0004523) KeypadButton kpButton=2.
CCM will then process the keypress based on the state of the call. What are you trying to do and where is the problem?
Kevin
173
