ATA 186 and Input errors (runts) at 12 sites
Have 12 sites w/1 ATA 186 with 2.15ms code on them. all plugged into 3524XL PWR switches. All are getting input errors increase all the time. Runts match input errors. Only on switchport with ATA. Have hard coded port, moved it to other port, tried different cable, etc and same thing. The ping response from switch to ATA is also 60-70ms which is kind of weird.
Anyone run into this before and have a fix?
I found a previous discussion, with a single ATA that went bad apparently but this is across 12 different locations so find it hard that all 12 would be bad.
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.eea46f1/11
Also, In CCM there are transient connections every couple seconds for all these ATAs. No device register/unregister messages though, just transients. Users have not reported any problems with FAX machines off ATA that we know of.
Just trying to clean up event logs and these runts.
1 ACCEPTED SOLUTION
Re: ATA 186 and Input errors (runts) at 12 sites
I haven't seen any particular problems with ATA's in general in this scenario, but I'm using the 2.16ms code, so you could try this. As for the transient connection attempts, it could be that the second analogue port on the ATA is not configured, so the second port may be contunually trying to register. If auto registration is off, this may be the cause.
HTH,
Bill.
HTH,
Bill.
Bill, Thanks. That fixed up the error logs. Didn't think of that.
174
