ATA 186 does not support hotline with IP dialing procedure.
In a network without gatekeeper, I make H.323 calls from one ATA to other ATA, dialing in nn**n*n*n*n# format.
When I put the string in DialPlan as hotline number H0nn**n*n*n*n#, it does not work.
Can anyone help?
1 REPLY
Silver
Re: ATA 186 does not support hotline with IP dialing procedure.
For one Cisco ATA to access a specific FXS port on another Cisco ATA, you use an IP dialing procedure. The Cisco ATA originating the call must have the following information about the destination Cisco ATA:E.164 phone number of the destination FXS port
IP address of the destination Cisco ATA
To enable the IP dialing procedure, you need to set the IPDialPlan parameter to 1 to instruct the Cisco ATA to look for the destination IP address in the dialed digits
.http://www.cisco.com/en/US/products/hw/gatecont/ps514/products_administration_guide_chapter09186a0080160f6f.html
185
