ATA-186 Phone 2 port problem
I connect to two ATA-186 to take the Fax function. When i connect to two ATA-186 Analog port 2, the fax machine can not take any action. I try to connect to the both Analog port 1, the fax machine can fax in several time. What is the problem When Both fax connects to analog port 2 ?
1 REPLY
Re: ATA-186 Phone 2 port problem
Are both ATA devices on the same network or are the calls in question going through a gateway? I am assuming that you have verified the settings on all of the ports and have found no differences in them. Here is a link to a fax troubleshooting document for the ATA-186 on CCO in case you haven't already found it...
http://www.cisco.com/warp/public/788/ata-fax.pdf
Pat
166
