ATA 186 (SIP coverted to SCCP) will not register to CM
I have a situation where SIP ATA's were ordered instead of SCCP. I downloaded and upgraded the ATA's with Version 3.2.3 software for SCCP. The ATA's pull ther configuration form the callmanager tftp server, but they will not register with callmanager. Anyone have any ideas that might help?
Re: ATA 186 (SIP coverted to SCCP) will not register to CM
you can browse to the ATA, in 3.2.3 just to the ip-address
http://ata-ip-address/
Also, can you see errors in the CCM traces where the ATA tries to register to?
Is your environment using DNS, or do you have ip-addresses for CallManager server config?
you can access the ATA 186 using
http://IP-address/dev
Assuming that IP connectivity isn't an issue, Look at the configuration through the web, make sure that the CCM settings are in the page. If they aren't then make sure the SCCP settings have a '.' for the SID0, SID1 and that the TFTP has a 1.
Also make sure the '150' option is defined in your DHCP server
745
