ATA 186 with Billing machine
How should I connect ATA 186 with PCO Billing Machine, so that the calls are automatically registered and billed.
Re: ATA 186 with Billing machine
Since there has been no response to this post or the others you posted previously which are all similar, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, please avoid posting the same question again in duplicate but instead review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
What does the billing machine have for interfaces? Are the FXS? Wht are you wanting the ATA to do?
You might have seen the billing machine giving the printouts immidiately after the call terminates. The system goes like this...From my ATA box both the lines goes to Billing machine and then from billing machine I connect my telephone instruments. Problem is ...I have to press the activation button manually...which I want to be automatically taken. For this I have to Reverse Polarity on these 2 lines which can be configured on my ATA. Now how to Reverse the polarity and what will be the values ??
129
