ATA 186 without gatekeeper
I want to connect 2 ATAs 186 to make calls between them, but I don't know which parameters I have to configure. Could you recommend me any document or manual to read ?
Thanks a lot !
Regards, Anacelia
Re: ATA 186 without gatekeeper
Connect them directly to each other and each one will be the other's gateway.
Can i establish calls between two ata 186 with valid ip address using the internet.?
And what is the answer?
In "gateway" field on your first ATA type IP addr of second ATA, and vice versa.
95
