ATA 188 + Cisco 3550 and Dot1q trunking
I have been trying to get an ATA 188 to connect to a Cisco 3550 switch.
The config for the port is below
switchport trunk native vlan 2
switchport voice vlan 4
switchport mode trunk
Vlan 2 is the data Vlan and Vlan 4 is the voice vlan.
What I am trying to do is to get the Ethernet port to be in Vlan 4, and the Uplink port to be in Vlan 2. Is this possible with the ATA 188? and is the above port config correct?
Glen
  • Other Collaboration Voice and Video Subjects
Re: ATA 188 + Cisco 3550 and Dot1q trunking
ata is a voip gateway. no need to trunk, here is what I would do:
interface fastethernet 0/xx
switchport access vlan 4
You dont need any of the other configs, no enc, no dot1q, no trunk native .....
That would be fine if you wanted to connect a device to VLAN 4 on the ethernet port, but how would this work if Data and Voice traffic were on different VLANs?
For instance, consider a printer/fax combination - you would want to connect the fax port to one of the analogue lines on the ATA, and LAN connectivity through the pass-through ethernet connection.
Hi Glen,
I was wondering if you got an answer on this post. I am running into the same problem. I was able to get this to work by setting the switchport as an access port,
switchport access vlan 110
switchport mode access
switchport voice vlan 210
Tac said they did not know why the other was not working.
Mike
123
